Leaking clutch fluid???
Old 06-11-2005, 10:14 PM
osumx5's Avatar
Default Leaking clutch fluid???
I recently bought a 1990 Miata with 15,000 original miles. The clutch fluid keeps leaking, but it doesnt leave any spots on the ground. Anyone know what might be wrong?
Old 06-12-2005, 07:52 PM
Default RE: Leaking clutch fluid???
Check the floor mat on driver side for spots of fluid. The cylinder behind clutch pedal mechanism has a rod and boot inside car if a typical clutch set up.
Old 06-12-2005, 10:35 PM
you also want to check the master cylinder, if the plunger in it is worn or cracked, you will leak amounts of fluid that may not be seen on the ground. I had this problem in the past, and it is a relatively cheap fix yourself, and not very time consuming.
ufcchokes
04-16-2014 08:43 AM
elitescouter
04-04-2011 09:59 PM
pat fears
05-05-2008 08:25 PM
unknownrsx
03-19-2008 11:33 PM
mag1
12-14-2006 10:56 PM
Quick Reply: Leaking clutch fluid???
