window switch reprogram
So, I finally got my car to the dealership to get the front headlight replaced (not the light, the assembly).
Anyway, the mechanics somehow managed to deprogram the auto run on the driver side window (the mode that has the window roll all the way up and down with one click). I tried finding the sequence to reprogram this, but I can't find it. Little help?
This is for the 06+ models. You did not specify your year.
http://www.imazda.com/forums/showthread.php?t=10986
did you get your window fixed?
Hi thedfo,
did you get your window problem fixed, I could do with help on the same problem please. By the way, my problem started AFTER the battery was disconnected so doubt that'll cure it!
Cheers,
Ross
Cheers,
Ross
