what engines can i put in a 05 mazda 6
RE: what engines can i put in a 05 mazda 6
It is not a stupid question. If it is the 3.0l V6, they are notorious for having issues with the PCV valve which has resulted in a lot of engine failures at very low mileage. http://forum.mazda6club.com/index.php?showtopic=43344. Thanks.
Engines are a lot like people, some live a long time and some don't, although preventive care goes a long way in both cases.
Having said that, I have a Mazda 6s, V6, I chekc the oil all the time and I noticed somethign really interesting that I have not seen in any of my previosu cars, after 1500 miles or so the oil is still clear, this is not the first oil change for my car but I keep noticing that it takes more miles than ususal for the oil to start developing that black color.
To answer the engine replacement question, you have to match the engine with the trans, personally I would stick to the original car config because you would have to midfy too much, including the ECU to get it to work right.
I'd check to see if the new Duratec 3.5 would work. It's supposed to be the same size as the current Duratec 3.0. Regarding the PCV issue, I've read about it and have been keeping an eye on my oil as well. It's a shame that a $12.00 part can potentially be the cause of a major problem. Didn't Mazda re-design the valve in 2006?
ORIGINAL: 93greenstrat
ORIGINAL: Mazmart Trini
Def. a shame that Mazda has had to replace engines due to a part that costs so little.
You do realize the 3.0L has been around forever...right?
Defects happen in any system to any manufacturer.
I've got the exact same 3.0L duratec 24V in my 2000 Taurus with 106,000+ miles on it and it runs like new.
ORIGINAL: sstlaure
