snow cables for the 6
Old 11-12-2006, 09:33 PM
toecheese's Avatar
Default snow cables for the 6
Anyone had any success finding snow cables that fit the 6? I know the manual says no cables but California says I need to have them. I've tried a few but they all rub the suspension. Anyone have any luck?
Old 11-13-2006, 02:45 AM
rx4to6's Avatar
Default RE: snow cables for the 6
Just wondering why you need snow cables for your tires in warm California ?
Old 11-13-2006, 03:20 AM
JBix's Avatar
Like the manual says, don't put them on the car. You will most likely cause damage to the car. Could be as little as just damaging the inner fender or some serious body damage. Could also damage the coil spring or other suspension parts. Get snow tires and show that you aren't supposed to use chains. Also, you can void your warranty if you are still in the warranty period.
Old 11-13-2006, 04:10 AM
toecheese's Avatar
Doesn't work that way here, I'm afraid. Drive in the mountains in the snow and unless you have a 4WD, chains/cables are required, period. Snow tires, warranties and manuals don't matter to the CHP. They will just turn you around on the spot.
I'm thinking a set of different sized, slightly narrower tires/wheels for trips to the snow might be the answer.
Old 11-14-2006, 12:49 AM
that would be your only option, thinner/smaller tire and a rim with an offset to to take it away from the upper arm. i think someone got cables on some 16's on his hatch?
Old 11-14-2006, 05:06 AM
JBix's Avatar
If you MUST use them, then I believe that would be you only chance, installing a smaller diameter rim/tire combo with a slight offset would help. I would go no larger than a 16 in rim with a 40 or 45 aspect ratio and some cable chains with rubber tensioners. I would also consult with a service shop or dealer to see what they say. Good luck to you.
myrose4me
12-05-2015 12:34 AM
enildo92
09-01-2011 08:15 AM
undeadxsunshine
12-21-2009 08:10 AM
Dieseltank
07-30-2009 10:38 AM
ysr04
04-21-2008 11:30 AM
Quick Reply: snow cables for the 6
