Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda6
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
  #131
Old 04-11-2012, 12:31 PM
Update: Its been a while but still not fixed. I have been looking for another good shop to take a diagnosis. Found a place actually near me which is easier logistically for me to get to, but they charge for the diagnosis. At this point I don't care as long as they fix or find the problem.
Car is there right now. They are pretty stumped, they've done a smoke test found no vacuum leaks and are doing something with propane and an ossciliscope and checking everything in the car (its a smog guy who's in a mechanic shop doing the diagnosis I believe). they noted all the parts replaced, will look at fuel system and everything else. The delay is I needed a day not on a weekend to do it and this is the first opportunity i got. will hopefully have an update in a few hours.
I've asked them to check these things mentioned so they're doing so.
Register today for free or log-in if already registered to remove this ad!
  #132
Old 04-11-2012, 12:49 PM
Quote:
Originally Posted by ms3-4life View Post
Its probably a long shot for your situation but i just had my 3.0l done and had codes for running lean and misfire. With regards to my thermostat and rad hoses. Fixed them up, engine light was gone and codes left.
Like i said most likely not your case, but check it out if you still cant fix her.
Good luck
I must have missed this. I do have a radiator leak (no fluid accumulation but they said there is one and there are signs of leaks) that I am putting off to fix after I figure out the lean codes.
I don't know how this all ties in together.....any thoughts?
  #133
Old 04-11-2012, 04:46 PM
The guy couldn't figure it out and gave up. Says he can't get the LTFT to drop with propane or something?
no charge but he said to take it to the dealer.... which I am going to do I guess.....different one that I've used before, they quoted $50 for the diagnosis (I didn't have to pay today since they couldn't figure it out...says it happens about 2 times a year with these codes). I'll only do the diagnosis, no work. I spoke to the guy, found no leaks, used propane to try to change the RPMs I guess and smoke test as well. They said there was something on the throttle body that was slightly leaking but they fixed it, but still couldn't get the LTFT to change. Also noticed the long screw on my MAF ( ).
I mentioned when I brought it in the EGR, fuel pressure, fuel injectors, intake plenum, issues (I got the feeling they didn't check the fuel pressure).
oh yeah, and triggered p0335 (pending), crankshaft position sensor? says that isn't related to the lean codes though.
  #134
Old 04-13-2012, 05:23 PM
Dealer service says recommending changing the fuel pump. Fuel pressure was at 50Psi, spec is about 64-75 or something. The recommendation says to replace and them and the MAF too and to retest it....not really a gleaming recommendation.
However the service advisor didn't know the filter and pump were one unit.....he seemed pretty green. They checked the brake booster, which they said was fine. I'll know more when i get the notes
Price: $900+ (only fuel pump), if the MAF is bad, I got that replaced at the mechanic and I'll just have them give me a new one.
I thought that was way too much, I'm going to call around and price shop. any thoughts?
  #135
Old 04-13-2012, 05:35 PM
2006 Mazda Mazda6
You were thinking about the fuel on Post #22. You had some other issues as well and we tried to make sure those issues were solved first. I finally did say check your fuel pressure on Post #42. I knew the fuel pump is not cheap (Post #47) and wanted to try other things first.
I would shop around. The fuel pump is in the gas tank under the rear seat (access is there).
__________________
2006 Mazda 6, 3.0-V6, 6 Speed ATX, 61000 km
MODS:24mm Progess Rear Sway, 1.5" Drop Front, LED int lights, K&N SRI to CAI with engine baffle, Steeda 1/2 Spacer, Battery insulated, Solar Panel, Pre-Cat Back Custom Exhaust to 2.5"Magnaflow Main Cat, MazdaSpeed Cat Back, 2V Hi Voltage Ign Coils, Water Shield, HiD Low Beams, 2 15" Subs, Extra Grounds, External Tranny Cooler, Tinted Windows, 180 T-Stat, Lucas Engine Oil, B&G Tranny Oil, Cut Throttle Shaft, Chrome Strips
  #136
Old 04-13-2012, 05:36 PM
Yeah, I asked several mechanics to check fuel pressure, but some didn't want to (said they didn't have the equiptment) or didn't take the time too, I guess I need to be more forceful with what I want them to do I guess. I hope this solves it...I'll call around but I need to get it done as my tags expire this month and I need a smog.
I'll post more of the service notes later when I get home (still waiting, have been here for 7 hours and its relatively dead in the waiting room). I guess the tech had to call up Mazda Service support or something like that.
Called a few guys around town:
Quote 1: Mechanic said $780 for the part alone, said probably sourcing from the dealer. (he estimated before calling his parts guy about $500 total).
  #137
Old 04-13-2012, 06:41 PM
question: I got the car back but it seemed sluggish on acceleration. I think they reset the PCM. Would that be consistent with the weak fuel pump as the computer has not adjusted to compensate? just wondering. they're looking at it now.
edit: they said everything is hooked up correctly. They said they did reset the PCM. hopefully the fuel trims will compensate back soon.
Another thought, my fuel pressure was 20-25% low from the published values, and my LTFT were at 20.3% pretty consistently, wondering if that had any relation.
OK....yeah, Fuel pressure check was 50 and the spec was 63-73psi.
13/63 = 20.6%......
are there any other factors here that you can think of before I go ahead and get this done? Fuel Pressure Regulator?
  #138
Old 04-13-2012, 10:30 PM
OK, now I get P2197 (02 Sensor Signal Stuck Lean Bank 2, Sensor 1) and P0160 ( O2 Sensor Circuit No Activity). I went to try to drive it a bit to re-program the PCM....blah. i have to take my dad to the dentist in the AM too, I'm going to go to the dealership again to see what's going on with this, hopefully its just relearning, but it shouldn't be doing this?
  #139
Old 04-14-2012, 08:38 AM
2006 Mazda Mazda6
Fuel Pressure Regulator-----it depends on how they did the fuel pressure test. I do like your thinking. If test was done before the fuel pressure regulator then it is your pump. If done after it could be either, more likely the pump. It's best to inquire and insist.
The stuck lean code makes sense since you are low on fuel pressure. P0160 not sure. Maybe they disturbed some wires. Get your fuel pressure fixed first.
However, you have enough miles on the car where the O2 sensor could be changed on Bank 2 Sensor 1 (which should be before the pre-cat on that side-----that is the sensor that monitors and gives info back to computer for the air/fuel ratio).
The O2 sensor has no bearing on your fuel pressure.
Run some more fuel cleaner thru it. Maybe they got some dirt in lines.
__________________
  #140
Old 04-14-2012, 01:08 PM
It drives better this AM. A little sluggish at times, but markedly improved since yesterday, still not comfortable with it.
I'm still tripping those two codes though. I looked online and it said if the O2 sensor was stuck it may trigger the p160 code as well.
Tags
04, car, causing, cel, code, exhaust, fix, kn, leak, lean, mazda, misfire, p0141, p0145, p0174, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
