Mazda 6 Headlights
I too am having the same problem but was told that my fog lights were burned out and there is no power. My headlights do not come on unless I put on the high beams. Can someone tell me why this is? I am told that the only night lights that are suppose to be on are the little ones on the far right and far left. Picutures if possible.
If your headlights only come on when you turn on the high beams, most likely your low beams are burnt out. There are instructions for replacing them in the owner's manual, and it is a very simple process (other than the space being a little cramped for getting your hand in there). I've done it many times, and once you're used to it, it can be done in just a few minutes.
As for the fog lights... I would verify that your car is equipped with fog lights, since as I mentioned before, not all cars have them (mine doesn't, but a family member's does). There will be a secondary switch on the turn signal lever for fog lights if they are available on your car.
I just joined this forum just to fix this passenger side headlight low beam problem on my 2003 Mazda6. I think the whole right fender needs to come off. Who designed this POC? Looks like all on the drivers side is readily accessible. Is there not an easy fix for this? The owners manual says take it in to the dealership. For a headlight replacement??!! I have a rear brake light out as well. I hope it isn't this problematic!
Segwayne
08-11-2009 06:59 AM
