Headlight adjustment.
RE: Headlight adjustment.
You can adjust up and down but not side to side on this application. I guess they fiqure that if you are off side to side then something is bent. Drawing below not very descriptive of location of screw so took a pic of the left side adjust screw with orange arrow pointing to it. Right side looks the same. Clockwise will raise them, counterclockwise will lower. #1 phillips screwdriver seems to work the best. #2 is a little to fat to fit down in the hole. Not sure if that procedure is in the owners manual.
[IMG]local://upfiles/1377/9D2B79FDC5124D2F961E86F34D1F3432.gif[/IMG]
STUFFF
02-26-2019 02:38 PM
