Headlight adjustment. - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 04-24-2006, 02:40 PM
Default Headlight adjustment.
Just wondering how to adjust the headlight beams on a mazda 6. I know that you can't do it from outside the car. So do I need to take the housing out or do I do it from inside the engine compartment?
Old 04-24-2006, 02:50 PM
Default RE: Headlight adjustment.
Have you looked in your owner's manual?
There should be a screw mechanism (one for up/down, one for side/side) Pop open the hood and take a look behind the lights.
Old 04-24-2006, 04:43 PM
yes, sslature is right. I did mine before...
Old 04-24-2006, 07:04 PM
You can adjust up and down but not side to side on this application. I guess they fiqure that if you are off side to side then something is bent. Drawing below not very descriptive of location of screw so took a pic of the left side adjust screw with orange arrow pointing to it. Right side looks the same. Clockwise will raise them, counterclockwise will lower. #1 phillips screwdriver seems to work the best. #2 is a little to fat to fit down in the hole. Not sure if that procedure is in the owners manual.
[IMG]local://upfiles/1377/9D2B79FDC5124D2F961E86F34D1F3432.gif[/IMG]
Thread Thread Starter Forum Replies Last Post
My mazda 3 headlight adjustment mechanism does not work anymore. STUFFF Mazda3 0 12-01-2013 10:57 AM
headlight adjustment mazda 5 for life Mazda5 4 01-24-2013 10:55 PM
replace headlight adjustment motor TycStyle Mazda Protege 0 06-30-2009 09:36 AM
Headlight Adjustment yurk72 Mazda Millenia 2 04-07-2008 12:43 AM
mazda 3 headlight adjustment wineye Mazda3 1 09-12-2007 10:34 PM
Tags
06, 2004, 2005, adjust, adjustment, alignment, cx7, headlamp, headlight, healight, lateral, localupfiles13779d2b79fdc5124d2f961e86f34d1f3432gi f, mazda, millenia, protege
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
