driver side power window/regulator
Old 09-30-2014, 08:05 PM
Danny Boy's Avatar
Default driver side power window/regulator
my window goes up and down but gets stuck in different spots. I have to pull it up really hard by hand when trying to close the window. motor/regulator sound fine. Could it be my gear is just stripped? The part would cost a lot less than buying a whole new regulator. Any one else have this problem?
Old 10-01-2014, 09:21 AM
hixx's Avatar
Most likely the regulator. I have replaced hundreds if not thousands of those since all the manufacturers went to the cable type regulators. What usually happens is a strand of the cable breaks and it is down hill from there. I like the Dorman regulators the best if a factory regulator is too expensive.
Old 07-25-2018, 10:07 AM
Vvn121's Avatar
I am having a similar problem... thus curious is you have any updates on how you fixed this.... Did did you change it yourself ?? Could i DIY it ? ... any instructions on how i could do it ?
Old 04-26-2022, 08:36 AM
BB_2012_CX9's Avatar
Default Same 3 of 4 windows
I have same issue on driver's. Already repaired on front passenger. Now rear passenger same issue. 75% of my windows end up with bad regulator and/or motor.
dmbrown003
09-10-2022 08:30 PM
1993 Mazda 323 BC Guy
10-19-2016 02:49 AM
Bigbaby
08-22-2014 09:00 AM
atmospheredesigns
09-24-2009 07:42 PM
gibber
10-06-2007 12:11 PM
Quick Reply: driver side power window/regulator
