Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda6
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 02-23-2012, 09:13 PM
Unhappy 2007 Mazda 6 Headlights Burning Out
2007 Mazda 6 keep replacing burned out headlights on both the Left and Right side. Had the Mazda dealer run my vin to make sure I was buying the correct bulbs. Purchased different brands of bulbs. Nothing seems to be working. Is anybody else having the same issue with their headlights? If so, what did you do to correct the problem.
Register today for free or log-in if already registered to remove this ad!
Old 02-23-2012, 10:37 PM
1997 Mazda 323
My Garage
What is your system voltage when you drive, higher than normal voltage will pop bulbs. Are your headlight housings loose? Are the connections to the bulbs tight?
__________________
1997 Mazda 323 1.3L 5-speed (130,000km)
2006 Mazda3 1.6L 5-speed (40,150km)
1989 Ford F250 7.3L IDI non-wastegated turbo 5-speed
239,000 miles and counting, ORIGINAL CLUTCH, still going strong. (In USA, dont have it here in AT)
Mostly
Always
Zipping
Dependably
Along
If I talk in this color it means I am speaking to you as a moderator, pay attention.
Old 02-23-2012, 10:46 PM
1997 Mazda 323
My Garage
This is why my Saab's lights were blowing constantly. I had corroded connections which raised the resistance of the wires, that overheated the connections and the plastic connector raising the resistance even more, it got to the point of blowing the bulbs in about 4 days, only realized it when the connectors fell apart in my hands from being baked.
__________________
Mostly
Always
Zipping
Dependably
Along
Old 02-24-2012, 03:33 PM
Thanks MazdaTirol...My mechanic checked the volts coming out while the car engine was being revved up and said it was in normal range. I will definitely have him check the connectors.
Old 04-15-2012, 06:09 PM
2004 Mazda Mazda3
Any updates on this one?
This seems to be a common problem w/1st gen 6's. It would be nice to figure it out.
I know car manufacturer's are trying to save weight (and cost) so they can tout better fuel mileage. Could it be they undergauged the wire so much that it can't even pull 55-60watts @ 12v w/o causing a resistance issue?
The "fix" may actually be rewiring from the fuse box forward using heavier gauge wire? Or, installing a relay and using heavier wire from it to the headlamps?
__________________
"Like" us on Facebook https://www.facebook.com/pages/Mazda...77350618947016
"There is no tool you can buy that will replace experience." - Josh Mills, C.K.DeLuxe/Koolhouse Publishing
Old 04-16-2012, 09:23 AM
Mazmart Trini's Avatar
Are you touching the glass part on the bulbs at all when replacing them? The bulbs will blow if you are coming in contact with the glass.
-Sheldon.
__________________
05 Copper 6S w/mods
87 Sapphire Blue RX7 TurboII w/mods too
Old 04-16-2012, 01:28 PM
Thanks Mazmart Trini! Definitely not touching the bulbs at all...taking extra time and care when installing new bulbs.
Old 04-16-2012, 03:50 PM
2006 Mazda Mazda6
Someone has a thread on condensation being a problem in headlights and tail lights. makes sense condensation will help corrode connections.
Mazda tsbs on condensation in lights
Service Bulletin 311161 for Mazda EXTERIOR LIGHTING | AutoMD
__________________
2006 Mazda 6, 3.0-V6, 6 Speed ATX, 61000 km
MODS:24mm Progess Rear Sway, 1.5" Drop Front, LED int lights, K&N SRI to CAI with engine baffle, Steeda 1/2 Spacer, Battery insulated, Solar Panel, Pre-Cat Back Custom Exhaust to 2.5"Magnaflow Main Cat, MazdaSpeed Cat Back, 2V Hi Voltage Ign Coils, Water Shield, HiD Low Beams, 2 15" Subs, Extra Grounds, External Tranny Cooler, Tinted Windows, 180 T-Stat, Lucas Engine Oil, B&G Tranny Oil, Cut Throttle Shaft, Chrome Strips
Old 12-16-2012, 11:39 PM
I had a 2004 that kept doing that, so i traded it in. But later found out it was a valus issue. I have a 2007 now and it does the same thing have to replace the head lights every other head light at least once a year.
Old 12-17-2012, 12:01 AM
1990 Mazda B-Series Pickup
Alot of the issue with them and u may not notice it but the holder that the bulb goes into get burnt/worn and that will cause the bulbs to blow due to varrying voltage. Also make sure not to touch the glass of the bulbs the oils from your hands will kill the bulbs. If u do touch the glass make sure to clean them off before installing.
Tags
09, 2006, 2007, burn, burning, burnout, burns, fast, headlight, headlights, mazda, mazda6, problems, remove, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
