shopping for a 2009 Mazda 5
I just found a 2009 Mazda 5 with 107k miles on it. The only major problem would be the airbag warning light keeps flashing on and off and I was wonder if it is an easy repair or I should skip this one and find another one
Hi,
you can read this topic to see if it's related. Also, you can look up the vin# and get a carproof report, that might give you a better idea if you need to look into a certain area of the car / engine / part to see if you can replace. Seems like a lot of risk to take.
other article:
https://www.mazdaforum.com/forum/maz...g-light-28068/
other article:
I have a repair shop look over the mazda5 before I brought it. The report came back as it was in a crash, car fax never had a report on it. The front air bag sensor are all damaged and needs to be replaced. I found another 2010 Mazda 5 with 65k miles on it for 9 grand. I brought that one and the only needs it neesd was oil change, all the filter needs to be swap out and the rear strut needs to be swap out.
mazdatree
11-16-2008 08:37 PM
