Serpentine & AC Belt Change
Old 10-09-2014, 02:23 AM
solsurf's Avatar
Default Serpentine & AC Belt Change
2008 Mazda 5 sport: Was wondering how difficult it would be to swap out my belts? It squeaks when the car first starts, but goes away after running maybe 20min. Did a search and found that you just cut the AC belt, loosen up the compressor to remove the Serpentine belt. Then reinstall. I'm pretty sure I can get that part going, but how hard is the reinstall. Once belts are on, how hard is it to get the compressor lined up for the bolts w/the belt?
It's either that or pay the $250 for the dealer to do it.
Old 10-09-2014, 10:34 AM
hixx's Avatar
Well it only pays .6 hours labor so i don't understand how the dealer figures it's worth $250 bucks. Rent the drive belt tool from a parts store and do it yourself. You don..'t have to remove the ac compressor.
Old 11-22-2014, 04:18 PM
Riptide262's Avatar
Ac belt is a stretch belt. Gates makes a tool to install the belt for a few dollars. Cut the old one off and use the tool and rotate the engine (with a wrench) to stretch the new belt on. Pretty easy job that took less than 5 minutes.
Old 11-22-2014, 09:35 PM
Once you have removed both belts, take a very close look at all the groves on all the pulleys. Dust & dirt gets squashed into the groves making funny noises. Get a pick and go over each groove & scrap anything out. Most noticeable on the air-con belt/pulleys.
Old 05-25-2015, 06:25 PM
rvluvin's Avatar
The Gates tool is not an engine specific tool, and will not work on an 09 Mazda 5. Loosing the compressor bolts and tilting the ac compressor didn't work either. I tried stretching and rotating the crank shaft with no luck. What finally work for me was to remove all 4 bolts from the ac compressor, slip the stretch belt onto the ac pully, line up the 2 front bolt holes of the compressor, and then using a bottle jack, I lifted the compressor into place. Luckly the rear 2 bolt holes lined up enough so that the bolts threaded in. After that the 2 front bolt went in, tighten them up, and the belt was on. Hope this helps someone!
Old 05-31-2015, 02:03 PM
Riptide262's Avatar
Default Gates tool
The gates tool worked fine for an 07. I can't speak to any other year but I expect it would work for any car with the same 2.3L engine with the AC compressor bolted directly under the engine drive pulley.
rhino1616
04-05-2012 12:01 AM
chb88
04-20-2011 11:34 AM
joe143
02-27-2011 02:36 PM
tvomalley
02-27-2009 01:26 PM
miamicris
10-15-2006 10:41 AM
Quick Reply: Serpentine & AC Belt Change
