Manual transmission 1st gear, reverse gear separator
Old 11-28-2016, 06:52 PM
p00ch's Avatar
Default Manual transmission 1st gear, reverse gear separator
I have a 2012 Mazda 5 with the 6-speed manual transmission. Normally, 1st and reverse gears are separated by some kind of 'blocker', which prevents you from accidentally shifting into reverse instead of 1st (forcing you to push down and left on the lever for reverse). Today, that blocker seems to have failed (disappeared?) and the level moves freely all the way to the left, making it tricky to find 1st without hitting reverse.
Has anyone experienced this and if so, is it a simple fix? A quick google search found nothing. Any advice?
Old 08-07-2023, 11:56 PM
mbfish's Avatar
Default same problem
I believe I have a similar problem on my 2013. My wife hit a car today when she thought she was
in first, but the car went backwards instead. She then had trouble getting in first or second. I confirmed the problem then tapped down on the shifter and got it into first, but if I just push left and up it goes into reverse without pushing down. Did you find a solution to your problem?????
[QUOTE=p00ch;160233]I have a 2012 Mazda 5 with the 6-speed manual transmission. Normally, 1st and reverse gears are separated by some kind of 'blocker', which prevents you from accidentally shifting into reverse instead of 1st (forcing you to push down and left on the lever for reverse). Today, that blocker seems to have failed (disappeared?) and the level moves freely all the way to the left, making it tricky to find 1st without hitting reverse.
Has anyone experienced this and if so, is it a simple fix? A quick google search found nothing. Any advice?[/QUOT
Old 08-08-2023, 07:16 PM
p00ch's Avatar
I just gave up and had the mechanic install a new reverse lockout. I've been driving manuals for decades and never seen this happen.
MazdaTirol
02-09-2012 03:57 PM
moogyd
10-28-2010 01:07 AM
axel_2078
08-20-2010 05:02 AM
bobby.e
08-08-2009 01:46 PM
Motormouth
03-03-2007 10:14 PM
Quick Reply: Manual transmission 1st gear, reverse gear separator
