Looking at buying - advice please
Looking at buying a 2006 TS diesel, 100,000 miles, engine sounds ok, mostly in good condition, couple of scratches here and there, but need a little advice.
Engine runs fine, doesn't blow smoke on startup or revving, how much is the DPF a problem.
Cambelt interval?
Only initial issue's are:
Passenger window doesn't open using the drivers switch but does using passenger switch, are the switched easy to get hold of?
Passenger wing mirror, motor appears to work but the mirror doesn't appear to be attached to the mechanism.
Also, can you get boot covers etc?
Thanks,
Steve
Cambelt interval?
Thanks,
Steve
