Luminics bulbs
Old 01-10-2009, 10:18 PM
M3 For Second Time's Avatar
Default Luminics bulbs
Has any used the Luminics Bulbs 55W? If so did you order the extra wire harness? I just got mine installed and they get damn HOT. I just ordered the harness just to make sure i dont fry anything. The box says 55w but right under that it say 130w so I'm not sure if these are just too hot.
Old 01-11-2009, 03:15 AM
04Mazda3Sport's Avatar
Default RE: Luminics bulbs
That 55W you see is the draw, and the 130W is the light output. The general concensus is that no halogen bulb will put out anymore light than it draws. Like I said in a previous thread, I have the Luminics 65 watt high beams and it says 130 watt output, but it doesn't put out anymore light than 65 watts. Mine don't get any hotter than a regular stock bulb. The harness is mainly for the higher wattage bulbs, such as the bulbs that draw more watts than the stock wiring will support, so that you don't fry your wiring. So basicly, if you see a bulb that says it puts out anymore light than it draws, chock it up as glorification for the manufacturer to sell more of them.
Old 01-11-2009, 06:15 AM
Well, 65x2=130?? Sounds like a bunch of advertisinghooey to me though.
Any halogen that only draws X amount of power, 55w in this case but is said to be capable of producing more lumen's than an OE of the same rating is over driving the tungsten/halogen element.In short, they are using a thinner piece of tungsten wire as the base for the filament.The bulb will burn out much sooner and is more susceptible to vibration damage as well.
Good explanation, Scott!!Good job!!You really do have an eye for the details.
Old 01-11-2009, 01:32 PM
The fog lens just gets to hot to touch and I was worried the it would melt the plastic. I order the wire harness just for safety measure but I will keep you posted if it fry's its self with time. Thanks guys for all the info. This is why I this forum is the BEST. Because of great input from guys like you.
Old 01-11-2009, 05:51 PM
Thank you Richard, and thank you M3. That is all just from experience and so on. Much appreciated from both of you.
Old 01-11-2009, 07:32 PM
ORIGINAL: M3 For Second Time
Yes, thanks for the compliment, Juan. I"d say that we are allafriendly bunch of gear heads, in general and that we try to help when we can.
Under the circumstances you describe then, may I suggest that you are very cautious to turn the fogs off when you will be sitting for a long time... such as when stuck in one of those famous California traffic jams?
Old 01-11-2009, 08:27 PM
jaimie08mazda3's Avatar
question though. how hard would it be to get a pair of fogs for my car lets say.
Old 01-11-2009, 09:42 PM
And I go with the standard answer, Ebay!!!!!! Yay, grand ole' Ebay!!!!! Cheap crap and even quality OE parts!
everythingzen
12-12-2006 07:12 PM
sin6racer
09-05-2006 06:57 AM
mikeyhd
05-06-2006 09:27 AM
poboxjosh
09-13-2005 08:23 PM
rotormotor2
05-11-2005 04:33 AM
Quick Reply: Luminics bulbs
