need help asap
Old 02-27-2007, 03:38 PM
mazda3power's Avatar
Default need help asap
two things. driver side headlight has fog up on the top. i checked the seels and everything and they are all fine. second things is that i replaced the bulbs and now i had to constantly move the harness connector to get the light to come on and now i cant even get it to come on doing that could i have fried the harness? help needed fast im a delivery driver and cant be on the road with 1 headlight.
Old 02-27-2007, 06:28 PM
sstlaure's Avatar
Default RE: need help asap
Were the seals for the new bulbs the same as the seals on the stock bulbs? That could be the source of your moisture. Try putting the stock bulbs back in and see if you still have the problem.
If you dostill have the problem with the stock bulbs reinstalled, then the problem is in the harness, if not, then it's in your new bulbs.
suafai
11-04-2009 04:22 PM
burton420
07-16-2007 04:26 PM
OneEyedBadger
03-26-2007 10:28 PM
OneEyedBadger
03-26-2007 04:41 PM
skooter0702
06-29-2006 03:37 PM
Quick Reply: need help asap
