mazda 3i lug pattern nad offset
Old 01-25-2006, 09:12 PM
mzd3_stratblu's Avatar
Default mazda 3i lug pattern nad offset
can anyone tell me the lug pattern of the mazda 3 is it 5x100 or 5x114. and whats the offset?
Old 01-26-2006, 01:29 AM
Default RE: mazda 3i lug pattern nad offset
Also i was looking into the scion tc rims. i heard they fit mazda 3's. is that true?
Old 01-26-2006, 03:00 AM
I believe the lug pattern is 5x114.3 and the offset, from factory is like 70...but you'd be ok with a 7.5 in. wide rim, as long as your offset isn't any bigger than 45. if you go with an 8 in. rim you'd want your offset higher. I am currently looking into buying 18 in. rims, 18x7.5 5x114.3 with an offset of 45,..and every dealer i talk to says i'm good to go.
Old 01-26-2006, 09:56 AM
sstlaure's Avatar
Lug pattern is definitely 5x114.3. Any stock Mazda rim out there will fit on the 3. I have the Mazda6 17" wheels on my 3i. Offset is 60mm.
Mazda3 - 17x6.5"
Mazda6 - 17x7"
RX-8 - 18x8"
Old 01-26-2006, 04:17 PM
ORIGINAL: sstlaure
Mazda3 - 17x6.5"
Mazda6 - 17x7"
RX-8 - 18x8"
Will 5x100 rims fit the 3 ??
Old 01-26-2006, 05:51 PM
sstlaure's Avatar
ORIGINAL: mzd3_stratblu
No...The way bolt patterns work is like this. A 5x114.3 pattern means 5 lugs, with opposite lugs being 114.3mm apart. (If you numbered the lugs 1,2,3,4,5.....The spacing between 1,3 or 2,4, or 3,5, etc would be 114.3mm apart.)
The 5x100 wheels wouldn't fit.
Old 01-26-2006, 06:19 PM
sstlaure: Thanks for the help. I didnt know that haha.
dvd7227
08-14-2011 09:22 AM
ecwrt
03-23-2007 11:28 AM
supermanwithheat
11-26-2006 06:54 PM
mizter_2
05-27-2006 05:13 AM
dieth
04-23-2006 11:57 PM
Quick Reply: mazda 3i lug pattern nad offset
