Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda3
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 08-23-2011, 04:36 PM
Default Mazda 3 Stalls when AC turned on
Help please - I was driving my 2005 Mazda 3 today with my AC on and I started hearing a noise and smelling a hot smell coming from the engine. The noise sounded like something was loose and flapping around. I turned off my AC and the noise stopped and my car appeared "fine". My engine did not appear to get hot as the needle stayed mid-way between hot and cold.
I arrived back at work and turned off my car. My boss opened the hood of my car and asked me to turn on the car. With the AC in OFF position, the car turned on and idled - sounding fine. As soon as I turned the AC ON to level 1 or higher, the car stalled. This happened several times when I turned the car off and back on again.
Prior to today, I've noticed the green light on the AC button turn off without me turning it off myself. Not sure if that has anything to do with it.
Any thoughts on what's going on would be much appreciated! I called the Mazda dealer and spoke with someone in service who didn't right away know what was going on....
2005 Mazda 3, 96K miles
Thanks so much.
Register today for free or log-in if already registered to remove this ad!
Old 08-25-2011, 11:50 AM
I'd guess the AC compressor siezed up - that would cause it to stall when the engine is loaded with a 'dead' accessory.
The green light should be completely seperate - though my 07 automatic system could easily be wired different from your 05 manual version.
With the engine off, you can reach the AC compressor and move it by hand (think you need a wrench on it though), if it doesn't move that'll be your problem. You can also look at that pulley when the engine is running and someone turns on the AC, if it turns or not will be the test.
__________________
Dave - 2007 3GT - black, badges removed, door bumpers removed, auto up windows, backup sensors, adjustable HID headlight modification, current limited high beams, fog lamps able to be on with parking lights only, under seat subwoofer. I'm usually on mazda3club.com instead of here - where many of the above 'mods' are that show in my signature.
Used to have GSL-SE's too
Old 08-26-2011, 02:07 AM
Tracker's Avatar
a/c compressor is shot, be prepared to spend about $300+ for a new/reman one
__________________
"Street racing or going to the grocery store, either way the potential of hitting an innocent bystander is the same, just one is more fun than the other."
Active Officer of street racing unit
Tags
2005, ac, air, car, conditioning, dies, engine, mazda, mazda3, noise, stalling, stalls, stop, turn, turned, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
