Low Beam Issues
Old 04-18-2014, 01:38 PM
natcon's Avatar
Default Low Beam Issues
Hello there,
I have read some treads here but no answers yet. I have a 2006 mazda 3 with 212,xxx on the engine.
I have no low beams. I have high beams, and dtrl. Fuses are good. wondering what people have found the fix was. Whether it be the light switch or having to replace the fuse panel under the glove box as it has built in relays for the headlights.
Old 04-18-2014, 01:51 PM
Does your car have factory DRL's? Does it also have HID headlamps? If it does, are they factory installed or aftermarket?
Have you checked for voltage at one or both of the headlights?
With electrical problems you have to decide whether to start at the source, or what is supposed to be functioning and work either forward or backward from there. In the case of headlights, its usually easier to start at the bulb and/or socket.
Old 04-19-2014, 04:27 AM
Do you have power & earth at the bulbs?
blue12
11-04-2021 03:28 PM
twcinnh
12-09-2010 09:48 AM
mazda guy
04-27-2009 07:48 AM
dulcetcalamity
10-31-2006 10:16 AM
mazdafan
04-29-2006 02:35 PM
Quick Reply: Low Beam Issues
