Hit tire tread in road, now every light on dash is on but no leaks??
Old Apr 19, 2012 | 07:37 AM
rags2bitches's Avatar
Default Hit tire tread in road, now every light on dash is on but no leaks??
Hi, first off, I'm new to the forum! I just bought a '10 Mazda3-S 6-speed 3 weeks ago. 3 days ago, I accidentally hit a strip of semi tread laying in the road. Upon getting to work, it looked like all it did was rip apart all the plastic undercarriage coverings. So I decided to simply remove them. No wetness, from what I could see no broken wires, just dragging plastic on the ground. Since then, I noticed intermittently as I drive highway speeds, I hear something that sounds exactly like the inner fender plastic rubbing against the tire. I look again, but could see no marks of the tire hitting the inner fender liner. Last night I go 1/4 mile up to Krogers to pick up a few things. It drives fine. No hesitation, no lights on, no nothing. I get back in and start going home. I look down, and I have traction control light, power steering light, check engine light, dsc off light, reduced engine power, abs light all on and my low tire light is flashing and I have no power steering. I get home and inspect the belt and fluid levels, all of which look just fine. I let it sit overnight, go out there this morning. No spots underneath, all fluids are still at proper level, and all the same symptoms are happening when I turn it on. Therefore, I'm thinking it's something electrical. Now, I work as a service writer at a GM dealership (hey, nothing screams 'job security' like fixing Chevrolets for a living) and when reduced engine power, service stabilitrack, check engine light, and abs light comes on, 95% of the time it's either a wheel speed sensor dropping voltage (replace the hub), or it's the accelerator pedal losing voltage. Could this be the same for Mazda? Or did I hit some sort of wire that I'm not seeing perhaps? Since the rubbing is coming from that one corner, I thought MAYBE if could be the right front hub that's been torn up and losing signal with the speed sensor. Any and all help would be great!!!
Old Apr 19, 2012 | 08:40 AM
UPDATE: Scanned system found 6 codes. All of which are 'loss of communication with pcm/abs/power steering/etc....'
Old Apr 19, 2012 | 11:47 AM
MazdaTirol's Avatar
Sounds like a wire harness was damaged in the impact or was shaken loose. Do they mount the PCM on the fender?
Krameryah
Jul 31, 2009 10:10 PM
friendlynerd
May 22, 2009 10:08 PM
MrSpike118
Mar 9, 2009 09:28 PM
chefskitty
Oct 15, 2006 01:18 PM
jakejohn
May 14, 2006 11:20 PM
