2008 Mazda 2 noise when cold
Good day every one, my M 2 has done 80000 km & of late there is a staccato like ticking only after the first start in the morning when I engage 1st gear & drive off. After a short distance this disappears for the rest of the day. My concern is it seems to be getting worse.
Can anyone offer some advise as to what it might be please.
Hello, my 2008 1.5 2 DE has the same problem. I've checked the timing chain, VVT actuator, adjusted the valve clearance...but it still makes noise when cold starting it. Has anyone solved this problem? The noise is as follows:
. You can hear it at 22 seconds - the rest is injector noise (totally fine). Thank you for your answer.
My turn only this is a perfectly as humanly possible performing and health checked engine.
VID 20210803 121551614 - YouTube
Hello, my 2008 1.5 2 DE has the same problem. I've checked the timing chain, VVT actuator, adjusted the valve clearance...but it still makes noise when cold starting it. Has anyone solved this problem? The noise is as follows: https://youtu.be/z8Y4Tpm-_fw?t=22. You can hear it at 22 seconds - the rest is injector noise (totally fine). Thank you for your answer.
But that ain´t the Mazda 2 DE mate, seems like newer one with SkyActiv.
YES! This is exactly the sound I get when cold starting mine. Lasts like 10 seconds of driving then disappears. It happens on every cold start, even in the summer. What's your lineup? I have a 2008 1.5L 76kw, 160,000 km and run 5W-40. Some YouTube guys have the same problem with 0W-20 as well. How long has your car been making this noise? Mine does this since I bought it from the previous (first) owner last year. Looks like it is not getting any worse.
As for the viscosity of choice unless you use a drastic change like a 20w50 and even then, I would doubt it would make difference unless using it in 10F degree or lower ambientes. See basic information for temperature operating viscosity of oil charts and DATA.
'08 Mazda 6 2.3 Non-Turbo
Does your noise sound when you start the engine or when you start driving? I have similar sound to my M2 too. My car sounds like this https://youtu.be/ammv3bsq3O8
