2004 Mazda 2 Sport ODB II Error Codes
p { margin-bottom: 0.1in; direction: ltr; color: rgb(0, 0, 0); line-height: 120%; }p.western { font-family: "Liberation Serif","Times New Roman",serif; font-size: 12pt; }p.cjk { font-family: "WenQuanYi Micro Hei"; font-size: 12pt; }p.ctl { font-family: "Lohit Devanagari"; font-size: 12pt; } Hello All,
I have a 2004 Mazda 2/Demio with about 45000 miles on it.
Using the Maxiscan MS309 ODB II/EODB reader for diagnostics, I get the following 8 error messages:
1/8: P0715 $07E8 Generic
Input/Turbine Speed Sensor A circuit.
2/8: P0351 $07E8 Generic
Ignition coil A primary/secondary circuit.
3/8: P0733 $07E8 Generic
Gear 3 Incorrect Ratio.
4/8: P0841 $07E8 Generic
Transmission fluid pressure sensor switch A circuit Range/Performance.
5/8: P0031 $07E8 Generic
HO2S Heat Control Circuit Low Bank 1 Sensor 1.
6/8: P0351 $07E8pd Generic
7/8: P0841 $07E8pd Generic
8/8: P0031 $07E8pd Generic
So can anyone tell me what needs to be done, in terms of dealing with these errors? Much appreciated.
Regards,
Dan.
Regards,
Dan.
I will do that and get back to you.Thanks!
