Trouble Code P0101 back again
YES it`s back again CEL light came on today after 600miles. Checked codes and it showed P0101
(There is also a rattling, tapping noise from under the front engine cover)
After changing the MAF sensor, a new Air Filter, cleaning AIC valve and replacing silicone vacuum pipes it is back even after resetting the EEC. I have added both of these to the fuel tank this first and then this
and I still have this to spray into the Air Intake downstream of the MAF to do a engine de-coke
The only thing that I have not cleaned yet is the Throttle Body as this Power Boost may do that
Is there anything else that I have overlooked or forgotten to DO or clean? Please Guys
as this problem is putting me on the verge of selling off this dam Son Of A B**ch Mazda Tribute
The MAF sensor is 2 months old, it`s a Delphi from Rock-Auto.com
I will use some Servol 10 electrical contact cleaner on the connectors tomorrow and hope that it fixes the problem - Thanks Kevinkpk
Yes Unmodified BUT clip loose on concertina hose air intake end, tight on throttle body end
Just went for a drive and the light remained OFF I will have to check that jubilee clip regularly
maestro
05-30-2007 07:36 PM
