2002 tribute headlight trouble
Old May 13, 2009 | 12:32 PM
kytribby's Avatar
Default 2002 tribute headlight trouble
Before my alternator went out on me, my lo-beam headlamps stopped working. The hi-beams work fine, but only the lo-beams do not work.
Any help would be greatly appreciated.
Thanks.
Old May 13, 2009 | 07:29 PM
04tributelxowner's Avatar
Could be a relay switch under the hood, or the switch in the turn signal lever stalk that turns on the high beams could be bad. I had this happen on a Dodge Caravan I used to own. Another thing to check is if there is a separate fuse for the low and high beams. Could be as simple as a blown fuse.
Old May 14, 2009 | 03:53 AM
kytribby's Avatar
thanks I'll be sure to check all of the fuses, and get back...
thanks again.
gregbeyer
Feb 10, 2014 07:59 AM
Clueless
Dec 9, 2010 09:43 AM
aa225
Jan 26, 2010 02:22 PM
02 B3000
Jun 5, 2007 12:04 PM
morecowbell
Jul 21, 2006 03:37 PM
