Squeaking sound when i turn the steering wheel
Old 10-11-2009, 12:23 PM
Crazy Hussar's Avatar
Default Squeaking sound when i turn the steering wheel
When i turn the steering wheel from center to left, it makes a squeaking sound. Any clues on what it could be. It is really annoying in parking lots and when i have to turn the steering wheel left. Any ideas?
Old 10-11-2009, 06:18 PM
I once rented a brand new Ford truck from U-Haul that did that. Since it was a rental and I didn't have time to take it back to have it looked at, I simply lubricated the steering column. Of course the horn didn't work after that either, but it didn't squeak!!
Old 10-15-2009, 08:38 AM
02LXV6AWD's Avatar
Default squeaking vs groaning
My 02's steering just started to groan when it's cold, mostly when turning left. The steering wheel doesn't pull, but I'm concerned about that sound. It isn't a squeaking, so perhaps the problem is something else. It is a high mileage vehicle, and this may be a Ford part (I find Ford's generally noisy).
The power steering fluid is not low. I'll be taking it for an oil change soon, and the shop is famous for checking everything and selling me all sorts of services, so maybe they'll find something that's repairable.
However, if anyone has anything to offer, please do (sorry if I'm hijacking this thread - not intentional - squeak/groan....they are both noises :-).
Cheers, Mark
Old 10-31-2009, 07:47 AM
sweetpea1836's Avatar
Default Steering groans when cold
I just went to the dealer yesterday for the same exact problem on my 01 V6 2WD. They said that my power steering pump was going bad and quoted a $628 bill including pwr steering flush.
Old 10-31-2009, 09:00 AM
04tributelxowner's Avatar
That seems a bit pricey. With the P/S pump being changed, you'd figure they would throw in the flush for free. If I were you, I would go to another dealer or an independent shop and get qouotes form them. You may want to consider checking with a Ford dealer to see if they would do the job.
Old 11-01-2009, 08:01 PM
Default Power Steering Groans
Thanks 04Tribute, I am going to an independent tech to have it replaced. I thought it was rather expensive too!
Old 11-10-2009, 09:55 PM
tizlymdir's Avatar
I everyone, I sure do need your help for this one. It's about the code P0351, I put the coil #1 on #4 change all six spakplugs, went to the garage and have the injectors clean up, and the f?%$# code still on, do I have to change the injector? is there anyting I can do before I go to the dealer? And can you tell me where the ECM is, I'm thinking of changing it.
Thank's guys.
Old 11-11-2009, 11:27 AM
02LXV6AWD's Avatar
Default Update
Groaning sound on my LX was due to low PS fluid - simple fix!
Cheers, Mark
unborn0882
05-03-2012 09:21 AM
willow
12-23-2009 03:51 PM
neumannu47
11-18-2008 09:57 PM
H15A5H1
04-06-2007 09:45 PM
H15A5H1
04-01-2007 12:16 AM
Quick Reply: Squeaking sound when i turn the steering wheel
