Seven Speaker sub modification
Anybody ditched the garbage factory sub/amp?
Either way will be swapping out factory stereo system for a Sony wx900bt head unit with alpine speakers, tweeters, and sub.
let me know if anybody has done it, and I guess if I don't see anything back i'll just post what I get put together. biggest issue is mounting clearance on the swr-8t sub, but I suppose I can just add a spacer between it and the housing.
That is right, there is not enough space for the sub/amp, so I just only replace the stock radio with an aftermarket radio from seicane, it helps to improve sound quality and add other features. I didn't add other sub/amp to my car. but if you want to add that, you may consider to add to the trunk. : )
jracingprotege
04-07-2008 06:48 AM
