Intermittent Door Ajar Light
Old 11-29-2015, 11:10 AM
Johnr863's Avatar
Default Intermittent Door Ajar Light
I have a 05 Tribute with and intermittent Door Ajar light coming on. It's been driving me crazy. Tried the WD-40 trick but it didn't work. I was able to put the vehicle in diagnostic mode using the Trip / Reset button and cycling down to #31 - Door. With all the doors closed, the diag display shows "Door - C". As I open each door, the only one that change the display is the drivers side door. When I open the drivers side door, the dig display changes to "Door - A". When I close the drivers side door, the diag display changes back to "Door - C". None of the other doors change the display when opening and closing each door. What is the chance of having 5 bad door sensors?
Old 12-31-2015, 10:52 AM
2005Tribute's Avatar
Have the same problem with my '05 Tribute. Could not figure out which door it was and the alarm would randomly go off. Took it in to have a tech hook up his scanner and tell me it's the rear passenger door, the sensor is $150 and the labor was another $200. I just popped the door panel, cut the wires and tied them together to close the circuit. No light, or alarm, but also no power lock on that door. It's a quick temporary fix to shut the alarm up until I buy a new sensor.
qtband
12-05-2011 03:52 PM
angelito584
12-15-2010 07:14 AM
Hoosier56
02-20-2009 09:05 AM
wineye
11-03-2007 04:37 PM
tygel14
10-03-2006 04:03 PM
Quick Reply: Intermittent Door Ajar Light
