Head Gaskets
Old 10-27-2014, 08:19 PM
stevez28's Avatar
Default Head Gaskets
2001 v6 185k, cracked radiator for a while, never ran hot just added water. Blew 2 piece heater hose @ coupling- fixed, got hot on test drive- changed radiator/cap-hot on test drive-changed water pump/thermostat-hot on test drive, could only add water after getting hot then cooling down, finally got system full and ran normal (no steam from tailpipe) for about 20 miles but noticed system was under TREMENDOUS pressure, was going to flush system next day but could barely get it started and when it did start-constant white smoke from tailpipe but motor ran good. What are the chances of a warped/cracked head or block ? I can change the gaskets, but don't even want to fool with it if something is cracked or warped. Thanks
P.S. by water I mean antifreeze
Old 10-28-2014, 07:41 AM
hixx's Avatar
Yea, they really don't blow head gaskets since the gaskets are multi-layered steel. The cylinder heads warp instead.
Old 10-28-2014, 04:10 PM
stevez28's Avatar
That's what I was afraid of. Thank You
Old 10-29-2014, 05:41 AM
Get a TK test.
Old 11-06-2014, 07:51 AM
mig25's Avatar
No offense mate, but you had a cracked radiator , but instead of spending $63 dollars for a brand new Aluminum radiator , you risked losing your engine by adding water, ( not antifreeze ) for a while ?? OMG I cant believe that.
New Radiator Aluminum Core Plastic Tank Ford Escape Mazda Tribute ZZC215200 | eBay
dagreeny
06-17-2014 06:40 AM
WonovertoMazda
05-05-2009 07:52 PM
AJ
08-01-2007 12:29 PM
Alucard
08-14-2006 03:01 AM
keninn
09-03-2005 01:17 AM
Quick Reply: Head Gaskets
