Early morning rough idle
Old 06-13-2013, 07:44 AM
Adebiyi's Avatar
Angry Early morning rough idle
My Mazda Tribute 2001 Es V6 rough idles every early morning start. It idles roughly and then stalls. When car warms then idling gets to normal. When parked for about 8hrs it rough idles.
Ran a code check and came up with P1409.
Please, good people in the house, what's could be the solution to this issue.
Thanks in advance.
Old 06-13-2013, 08:06 AM
Found this (don't ask me to explain it):
DTC P1409: MEASURE RESISTANCE ACROSS EGR VACUUM REGULATOR SOLENOID
Diagnostic Trouble Code (DTC) P1409 indicates that Self-Test has detected an electrical fault in the EVR circuit.
Possible causes:
Open EVR circuit.
Open VPWR circuit to EGR Vacuum Regulator solenoid.
EVR circuit shorted to VPWR.
EVR circuit shorted to GND.
Damaged EGR Vacuum Regulator solenoid.
Damaged PCM.
Key off.
Disconnect EGR Vacuum Regulator solenoid.
Measure EGR Vacuum Regulator solenoid resistance.
Is solenoid resistance between 26 and 40 ohms?
Yes No
The EGR Vacuum Regulator solenoid resistance is within specification. GO to HE111 . REPLACE EGR Vacuum Regulator solenoid. RECONNECT all components. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HE111 CHECK VPWR CIRCUIT VOLTAGE AT EGR VACUUM REGULATOR SOLENOID
Key on, engine off.
EGR Vacuum Regulator solenoid disconnected.
Measure voltage between VPWR circuit at the EGR Vacuum Regulator solenoid vehicle harness connector and chassis GND.
Is voltage greater than 10.5 volts?
Yes No
GO to HE112 . SERVICE open in VPWR circuit to EGR Vacuum Regulator solenoid. RECONNECT all components. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HE112 CHECK EVR CIRCUIT RESISTANCE
Key off.
Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires. Service as necessary.
Install breakout box and leave PCM disconnected.
Measure resistance between Test Pin 47 (EVR) and EVR circuit at the EGR Vacuum Regulator solenoid vehicle harness connector.
Is resistance less than 5.0 ohms?
Yes No
GO to HE113 . SERVICE open in EVR circuit. RECONNECT all components. RERUN Quick Test.
HE113 CHECK EVR CIRCUIT FOR SHORTS TO POWER OR GROUND
Key off.
Breakout box installed, leave PCM disconnected.
Measure resistance between Test Pin 47 (EVR) and Test Pins 71 and 97 (VPWR) at the breakout box.
Measure resistance between Test Pin 47 (EVR) and Test Pins 24 and 103 (PWR GND) at the breakout box.
Is each resistance greater than 10,000 ohms?
Yes No
REPLACE damaged PCM. RECONNECT all components. RERUN Quick Test. SERVICE EVR circuit for short to VPWR or PWR GND. RECONNECT all components. RERUN Quick Test.
HE120 CONTINUOUS MEMORY DTC P1409: WIGGLE EGR VACUUM REGULATOR SOLENOID WHILE MONITORING VPWR
Continuous Memory DTC P1409 indicates that Continuous Memory Self-Test has detected an electrical malfunction in the EGR Vacuum Regulator solenoid sometime during vehicle operation.
Note: If DTC P1409 was output in Key On Engine Off (KOEO) or Key On Engine Running (KOER) Self-Test, go to HE110 to diagnose present fault.
Possible causes:
Open EVR circuit.
Damaged PCM.
Install breakout box, leave PCM disconnected.
Measure voltage between Test Pin 47 (EVR) and Test Pins 24 (PWR GND) at the breakout box.
Key on.
Voltage must read greater than 10.5 volts. For an indication of a fault, look for this voltage to drop while performing the following:
Lightly tap on the EGR Vacuum Regulator solenoid.
Wiggle the EGR Vacuum Regulator solenoid connector.
Grasp the EGR Vacuum Regulator solenoid vehicle harness connector and wiggle wires between solenoid and PCM.
Is a fault indicated?
Yes No
ISOLATE fault and SERVICE as necessary. RECONNECT all components. RERUN Quick Test. Unable to duplicate or identify fault at this time. GO to Pinpoint Test Step Z1 with the following data: DPFEGR and EGRVR PIDs and list of possible causes.
Old 06-14-2013, 02:33 AM
Adebiyi's Avatar
UseYourNoggin.. Thanks
Doggyx
09-11-2022 05:26 AM
bluedemon
03-15-2010 08:28 PM
Sprint57
11-27-2009 10:17 PM
93greenstrat
08-19-2008 05:13 PM
kennmonster
08-11-2007 07:56 PM
Quick Reply: Early morning rough idle
