dash lights and overdrive
Old 02-16-2017, 09:13 AM
alcamoz's Avatar
Default dash lights and overdrive
Hi,
I just purchased a 2005 Tribute FWD V6 122K miles. Nice ride, I like it.
Here is my situation. I just discovered that it had an OD switch. I hit the button a few times and never noticed any difference in revs. Besides that, I tried every trick I know to get the tranny to shift improperly. Up steep hills heavy and light pedal, stomping, manual shifting 1,2 D. Works correctly AFAIK. My mechanic drove it and said it it shifts nice. I'm at about 1900 RPM at 60 mph which I figure is normal for a 4 spd in the OD mode. I read that the tranny always defaults to OD on startup. I did discover that some of my cluster light are out including the OD light and the temp gauge light but I can't notice any difference when I press the switch... Any ideas as to what is going on? Thanks!
Old 02-16-2017, 03:55 PM
simonsi's Avatar
I'd guess the OD switch isn't working, that would expalin the behaviour and the lack of OD light. The Coolant light is driven by the level sensor in the coolant tank AFAIK so if that is unplugged again no light on the dash at any time.
Old 02-17-2017, 06:10 AM
alcamoz's Avatar
Makes sense. I'll sleep better tonite :-)
Appreciate your input..thanks!
Old 02-19-2017, 07:54 AM
peedee's Avatar
OD light only lights when it is off, it should illuminate on start up and then go out it actually say's O/D OFF when it is lit, it is not difficult to remove the cluster to replace the blown globes
Ransack
06-23-2022 09:43 PM
jpaschal21
06-17-2009 06:56 PM
anthonytsi
11-12-2008 04:37 PM
import_fan7
01-03-2008 10:36 PM
latitude20
05-28-2006 04:12 PM
Quick Reply: dash lights and overdrive
