Coil Packs - Mazda Tribute - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 12-30-2009, 02:16 PM
Default Coil Packs - Mazda Tribute
Hey all,
I'm going to be completely honest first of all and say I have no knowledge regarding vehicle mechanics. I recently bought a 2002 Mazda Tribute. This was the end of October. A few days later my engine light came on, eventually it started blinking. I had my mechanic test it and I forget the code he gave me, but he said it needed a new catalytic converter. I actually ended up taking it to a different mechanic that said it just had a bad coil pack. (it had recently been missing pretty bad while driving). Anyway, that seemed to fix the problem until a few days later, the engine light came on and it started acting up again the same way. We called him back and he told us it was probably another coil pack and to bring it back and he would replace that as well. I'm just curious if this is normal. Since I know nothing about this kind of thing, I would hate to think that my mechanic isn't correctly fixing the problem. Does anyone have experience with this? Does this sound normal, or do you think it really could be the catalytic converter? Thanks for all advice!
Old 01-05-2010, 03:09 PM
To be able to judge correctly, you should write down the codes.
Then, if the codes are different than what your mechanic is telling you, you might have an answer.
The coils on these cars go bad. Try to pick them up online, you might get a break and get them cheaper then what the dealer is charging. Also, if it's the front coils, these are easy to change. The rear ones might pose a problem, especially if you never wrenched before. If you have somebody who is good with tools, even the rear ones are not too bad.
Pending on mileage, I would also change the sparkplugs while I'm at it. You are there anyways - especially if it's one of the rear coils.
Old 01-15-2010, 08:21 AM
thanks so much for the reply! since I posted that, we had a coil pack changed out. It seemed to fix the problem for a week and then started up again... we took it back and they changed out spark plugs, and then it sounds like they just switched 2 coil packs around? I don't understand all of this, but it seemed to do the trick. Now it has been about 3 weeks and the light came back on. I plan to take it to a different mechanic and get the codes but I was wondering, would it be possible that I need a new catalytic converter instead? I know that bad coils can ruin the converter, but can it work the other way around too? Thanks again!
Old 06-07-2010, 04:40 AM
Hi All, just a quick note to let you know we had the same problem with our 2001 Tribute last year. After replacing a number of coil packs, our mechanic found out that there was a fault in the computer. It had to be sent off to be repaired (along with the ignition system and key). Ended up costing around $400 AUS. Has been great ever since.
Old 06-15-2010, 07:26 PM
guys check my post although im not mention it my engine light was flashing last week and yesterday i had a major catalyst breakdown . If you ceck this forum you wil find more info . there was a post by carfixer
here is the post
With the mil flashing you most likely have a missfire concern. coils, sparkplugs, are the most common problems. The one with the melted EGR valve you most likely have a damaged cat converter.[Plugged exhaust] To repair scan and test for codes. Check engine compression.fuel pump pressure. If you have missfire codes replace plugs,coils as nessasary. Missfires will damage the converters causing them to break apart causing the plugged up exhaust. With out codes and other information. I have listed the most common causes. I hope this helps Kevin
by the way the coils .... i saw them on amazon for 119 $
Thread Thread Starter Forum Replies Last Post
2005 Mazda 3 2.0 coil packs az350x Mazda3 0 08-18-2013 07:23 PM
Issues after new coil packs BizzleZX10R Mazda Protege 4 08-05-2013 12:40 PM
spark plugs and coil packs for sale in UK sammie419 Mazda RX-8 0 10-10-2011 06:07 AM
neone willing to sell coil packs compatible w/ 2001 Millenia 2.3L? ryanjeanes Mazda Millenia 0 07-08-2011 05:25 PM
Excessive changing on Ignition Coil Packs Dingo Mazda6 4 09-28-2009 09:31 PM
Tags
2002, bad, catalytic, changing, coil, converter, failure, mazda, miata, pack, plugs, problems, replace, spark, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
