Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Tribute
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 09-28-2009, 08:14 PM
Default clunk noise coming from suspension
i'm not sure what is it...might be ball joint or axle. i hear the clunk noise everytime i hit a small bump. anyone have any clue what it might be?
Register today for free or log-in if already registered to remove this ad!
Old 10-06-2009, 11:03 PM
Could be your sway bar links. They go bad.
They are easy to change (DIY).
The OEM part is TRW and fails easy. A quality aftermarket part (beefier) is the MOOG - K80104 part number. This one you can grease and will hold up nicely. It costs 13.79$ here. Other vendors will sell for about 34 bux or more. To change it yourself, you don't even need to take the wheel off. Basic tools plus a breaker bar and 10 minutes of your time per side.
Old 10-11-2009, 12:24 PM
Yup, its the sway bar links. Had the exact same problem. Its not as bad as you think it is.
Old 10-12-2009, 03:57 PM
Had the same issue with our 02 with 86k miles on it; turned out to be struts and strut mounts. I had a local shop check it out and they couldn't pin point the cause of the noise, ball joints and end links were fine. The clunking noise would only appear while going over bumps at low speed; sawing the wheel back and forth at low speed would not reproduce the clunking.
The Mazda dealer in town replaced the struts and mounts and voilą, problem solved.
My two cents, good luck!
Tags
2003, 323, clunck, clunk, clunking, clunky, coming, end, front, mazda, mazda3, millenia, mpv, noise, noisy, strut, suspension, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
