check engine light - Mazda Forum - Mazda Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 07-22-2005, 08:56 PM
Default check engine light
Hi...I drive a 2002 Tribute - never had any real problems with it. The check engine light came on the other day - per the owner's manual, I checked the fuel cap and filled up the gas tank (to avoid potential condensation in the tank) and the light went off. Stayed off for about a day and then came back on again. Can't get it in to the shop for a few days so I thought I'd ask if this has happened to anyone else and if so, what was the diagnosis of the problem and the resolution?
Thanks.
Old 07-22-2005, 10:07 PM
Default RE: check engine light
I suggest taking it to your dealer, because Mazda has done a number powertrain control module (PCM) reprograms. While the tech is checking for diagnostic trouble code, it only take a few minutes to check your PCM calibration & reprogram if available.
Old 07-29-2005, 11:09 PM
By far the most common problem with a check engine light would be an egr flow problem. The DPFE sensor is at fault 99.9% of the time and there is a warranty extension on this part that covers for 5 years or 74,000 miles. Code will probably be either a p0401 or p0402. Warranty coverage is provided by SSP 59.
Old 08-12-2005, 01:01 PM
I have a 2002 Mazda Tribute with about 25,000 miles on it. The check engine light came on about a week ago, and I have been lazy about taking it in, but after reading up on it here, I've decided to make the appointment. I'll report back on the results.
Old 05-24-2006, 08:06 PM
Is there a way that i can pull the check engine codes myself?
Old 05-25-2006, 08:54 PM
Not without an OBDII compatible scan tool like the ones in the links below. Many auto parts stores such as Autozone will pull the codes for free for you. Just take it in and have it scanned for codes. Come back and repost with what code you have. Just don't let then try and sell you what they think it probably is.
http://www.partsamerica.com/ProductD...artnumber=3030
http://www.partsamerica.com/ProductD...artnumber=1500
Old 05-25-2006, 09:21 PM
I second the idea of purchasing a scan tool and doing it yourself. This way you know the exact code and the confidence that the actual problem is being taken care of.
In additon, you will be able to run a scan for any future problems yourself also - without having to set-up an appointment, which could consume your whole day.
Old 08-27-2006, 03:02 PM
Quote:
ORIGINAL: babyhuey
Can you please tell me where this DPFE sensor is located? I have an 01 Tribute and my Check Engine light also stays on.
Thanks,
Frank
Old 08-27-2006, 04:16 PM
Once changing the DPFE, I believe I found it, connected to two tubes by the transmission dip stick, do I need to reset the check engine light? Or will it go off by itself? If I need to reset it, how can I do it?
BTW, can one post pics on this forum? If so, where's the "easy" button for that?
Thanks,
Frank
Old 08-28-2006, 03:21 PM
With all of the code sources in an engine I do not think you should start replacing parts based on the probability of what the code might be. You should get the code read first and then figure out what parts should be replaced.
Thread Thread Starter Forum Replies Last Post
Battery Light, No Check Engine Light Rockstar Mazda Protege 5 03-13-2015 02:07 PM
AT light check engine light help!!! KillerTofu General Tech 0 09-13-2014 11:35 AM
Mazda 6 Check engine light and TSC/DSC light staying on pdw001 Mazda6 2 12-09-2012 03:20 PM
Check Engine Light + Airbag Warning light brave-heart Mazda6 1 04-21-2010 08:44 AM
Engine Got Wet - Check Engine Light Stays On stoogefan32 General Tech 3 07-10-2009 08:50 PM
Tags
1f7220302, 626, button, check, dpfe, engine, light, mazda, miata, reset, rx8, sale, sensor, sport, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
