Bank 1, Sensor 2 - location?
The rear (firewall side of the engine has cylinder #1 so that is bank 1 and the front (radiator) side is bank 2. The #1 sensors are the closest to the engine in the exhaust manifold. FROM: http://www.justanswer.com/mazda/7q5w...e-v6-want.html
Yes Sensor 2 is right after the pre-cat.
Having Cat problems like this means you should try this first:
remove the negative terminal on the battery (this should have been done while doing repais). Followed by a few brake applications and honking of horn to make sure all active current is gone. Wait 10 minutes.
Re-hook-up negative terminal.
Re-start vehicle and let idle for 10 minutes. Re-learning has begun and will continue for 50-100 miles.
Symptoms There may be no visible symptoms to the driver. Poor fuel mileage, possible misfire, depending on O2 sensor position when sticking. Causes A code P0136 may mean that one or more of the following has happened: Faulty O2 sensor leak in exhaust close to O2 sensor, Short to voltage on O2 signal circuit, Open in circuit resistance caused by corrosion in connector
Possible Solutions Replace the second oxygen sensor on bank 1,
Repair open or short in signal circuit,
Clean corrosion from connector
Read more at: OBD-II Trouble Code: P0136 Oxygen O2 Sensor Circuit Low Voltage (Bank1, Sensor2)
Copyright © OBD-Codes.com
Common Problems That Trigger the P0130 and P0136 Code
Defective Oxygen Sensor/Air Fuel Ratio Sensor
Defective Oxygen Sensor/Air Fuel Ratio Sensor Heater circuit
Exhaust System Leak
Intake Air System leak (including vacuum leaks)
Low Fuel Pressure
Defective Engine Coolant Temperature Sensor
Defective sensor wiring and/or circuit problem
PCM software needs to be updated
Defective PCM
Wow. Thanks for the in-depth reply. I will definitely try and put that information to use.
I recently bought an ELM327 Bluetooth device and downloaded Torque onto my phone, and it looks like a pretty decent diagnostic tool. Of course the information it provides is a foreign language to me, but I'll work on that part.
I appreciate the help.
