Alternator
Old 09-10-2016, 03:55 AM
noel's Avatar
Default Alternator
Question for you part time elec people. If i put a tester on my car battery while she is idling should the voltage reading fluctuate. It jumps from 13.2 to 14.5, up down, up down. When engine is off it sits at 12.9.
Old 09-10-2016, 05:19 AM
Not looking good. Regulator is probably on its way out.
Old 09-11-2016, 03:42 AM
noel's Avatar
Thanks
grim_reaper. Would that in turn upset the engine management unit
Old 09-11-2016, 03:53 AM
As long as it stays within a range of 13-15v when charging ( engine running ) it should be safe.
I would recommend getting it inspected & replaced/rebuilt ASAP.
Old 09-11-2016, 04:12 AM
noel's Avatar
I will do that tomorrow. It varies at idle by one volt or so. Is that enough to inhibit the engine control / management from doing its job properly. I have noticed it will sometimes not go into overdrive. i have an oil leak on a rocker cover gasket. i will get that replaced first as that may have caused the fault in the alternator with oil leaking in to it.
bmorelikeme
06-24-2018 09:48 AM
rschlesinger
12-09-2005 12:47 AM
Dexxa
11-04-2005 01:28 PM
stargazer
06-29-2005 06:11 PM
jemhrm
06-07-2004 05:36 PM
Quick Reply: Alternator
