after warm up no power and misfire
Old 02-07-2017, 01:54 PM
thor1974's Avatar
Default after warm up no power and misfire
Hi,
I have a 2003 Mazda Tribiute 3.0v6. if I start the car the Engine is idle perfect after a short while if the Engine get warm the engine lose all power. I can step on the accelerator pedal and the rpm goes not up and the Car is not moving and the Engine is running very rough sound like only 3 Cylinders are working.
I replaced sparkplugs coils injectors fuelfilter airfilter everything. I hook up a scanner and get follow code P2179. I don't have a vaccum leak that I checked already. the O2 Sensors should not make this trouble if they would be damaged.
had someone here an idea what can cause this Problems???
Thanks
Old 02-08-2017, 12:24 AM
simonsi's Avatar
https://www.obd-codes.com/p2179
O2 sensors, MAF, air leaks.
Why do you rule out the O2 sensor? Clearly the bank 2 O2 sensor could cause this
Old 02-08-2017, 05:41 AM
I would be inspecting the catalytic convertors for deterioration &/or blockages.
Old 02-09-2017, 01:43 PM
thor1974's Avatar
the Catalyst was clocked the whole ceramic was meld. the o2 sensor was damaged. all is new but still have the same problem. the engine starts with hard misfiring and shut down if the cooling fan comes on.
I have no idea why? the Altenator is new and charge with 13.8V
Please help
Jaxxxon
10-19-2016 12:49 PM
poppashocker
08-25-2015 08:19 PM
mazdagnewb
11-07-2014 07:24 AM
VanilliwithafewMilli
01-02-2011 11:39 AM
CardsFan420
11-08-2006 06:25 PM
Quick Reply: after warm up no power and misfire
