2006 tribute stalls on start..help!!! misfire????
Old 11-16-2016, 01:12 AM
becsta81's Avatar
Default 2006 tribute stalls on start..help!!! misfire????
need help!!
my 06 tribute stalls on start but not all the time, usually when i've driven somewhere and left it sitting for an hour or so then try to start it.
It turns over and starts fine but then starts idling real rough to the point i can hear what sounds like the pistons jumping around in the cylinders, real jerky, then it eventually dies.
after turning off, i can then turn it over and it starts fine without a problem.
the car is idling and running smoothly otherwise, although, it would have to be the thirstiest v6 i have ever driven.
engine light is not coming on at all.
any help would be appreciated!!!
Old 11-16-2016, 05:43 AM
Could be a leaking injector.
Old 11-26-2016, 08:26 AM
rcenturion's Avatar
I had a similar issue a couple years ago and it was a bad coil on one of the spark plugs.
But, the check engine light was on and the diagnostic code revealed the bad coil.
Old 12-01-2016, 10:53 AM
Brit101's Avatar
An acquaintance had the same issue, it was the alternator. Same year as yours, v6 with 300,000 km. Warning it was a royal pain to change. Have someone check the alternator as described in a Youtube video.
Good luck.
I was looking here to see if others had the same difficulty, or knew of a trick to do the R and R .
steevec
12-06-2008 01:23 AM
got_mike35
11-19-2008 06:42 PM
mr_resistible
06-04-2008 02:44 PM
djwho
03-08-2007 12:58 AM
CardsFan420
11-08-2006 06:25 PM
Quick Reply: 2006 tribute stalls on start..help!!! misfire????
