05 tribute rumbles between 30 and 40 mph then smooths out
Old 02-06-2016, 11:02 PM
Ednero77's Avatar
Default 05 tribute rumbles between 30 and 40 mph then smooths out
My tribute sounds like I'm driving over rumble strips when I'm between 30 and 40 mph and then stops once I'm past 40 mph i was told it was the half shaft so i replaced it and it still doing it.
Old 02-09-2016, 10:45 PM
Sparky202's Avatar
4 wheel drive? I've seen the joints on the rear drive shaft seize but it's been awhile and I don't recall the rumble speeds. If the drive shaft bolts up on both the transfer case and diff, you should be able to remove it and take a ride. See if that eliminates the rumble.
Old 02-09-2016, 11:09 PM
Ednero77's Avatar
Default 05 Tribute rumble
It's awd. The car lot that hosed me on it said they replaced one of the u joints but I can't really trust anything they say.
Old 02-11-2016, 06:04 AM
peedee's Avatar
Actually 95% of the time the car is front wheel drive and only uses 4 wheel drive if you select it or the sensors detect an amount of slip in one of the front wheels and will engage the rear as needed to keep traction
Old 02-29-2016, 06:01 PM
JohnCT's Avatar
But everything is still turning 100% of the time as long as the rear wheels aren't dragging.
John
Old 03-02-2016, 12:00 AM
Sparky202's Avatar
Did you ever find a solution?
Old 03-02-2016, 07:27 AM
Dirtycar992's Avatar
I'm cousious about this.
Hondata Jacky
08-18-2014 03:59 PM
CADDMaz
10-28-2013 02:24 AM
welbyobeng
06-13-2008 12:20 AM
dove
04-24-2008 09:37 AM
Quick Reply: 05 tribute rumbles between 30 and 40 mph then smooths out
