RX8 won't start, suspect immobiliser issue :-(
Old 10-05-2010, 02:34 PM
steve2k1's Avatar
Default RX8 won't start, suspect immobiliser issue :-(
Hi, i hope theres someone out there who can help me.
I can't get my RX to start. i have two keys, both unlock the car remotely, but neither start the car.
The car has run fine since purchase, until this morning. it was parked up overnight, and wouldn't start today.
  • I have checked the battery which seems fine as all lights, stereo etc work.
  • I've checked fuses which look fine
The instrument panel lights up when turning the key, and the "Security Indicator Light" flashes repeatedly after everything else does what i would normally expect.
the car doesn't turn over whatsoever.
From what i understand, this means the car no longer recognises the key. i assume the fault is the car rather than key, as both keys have the same issue.
is it possible to re-programme the immob?? or is there ssome other fix i should be trying??
Really appreciate any help
Cheers
Steve
UPDATE:
Car started without hesitation this morning. key in, immobiliser light went off, and off we went. unfortunately the door ajar light stayed on, so i think the issue is to do with the secuirity system geting confused thinking its locked when its not and vice versa perhaps??
Has anyone else experienced this combo, and found any solutions??
Old 10-06-2010, 11:28 AM
djs2571's Avatar
The owners manual should have info on how to program new remotes, and I believe keys as well... I've also heard of the ignition reciever module (that looks for the key) to go bad, so it could be that as well.
Do start with the manual though, could be something simple to reprogram and you're all set.
What year / model is your RX8, could be a recall issue for one of the 'brains' in the vehicle with a bad connection.
Old 10-06-2010, 05:54 PM
steve2k1's Avatar
Thanks for the suggestion, I'll try to reprogram the remote tomorrow.
Car started fine this morning, but wouldn't again at lunchtime arghhh. Now it's abandoned at work.
My RX is the 230 version, 2004 model
hazchem69
11-13-2016 01:16 PM
mattstead
09-24-2010 05:36 PM
Slapsack
02-09-2010 03:16 AM
myk
08-23-2009 06:08 PM
boostn1g
12-14-2008 10:03 AM
Quick Reply: RX8 won't start, suspect immobiliser issue :-(
