immobiliser light
immobiliser light
Hi,
I bought a rx8 and it wouldnt start bit of a gamble, noticed the main fuse 120mp had blown, replaced it and all i get is ignition lights wont crank and the immobiliser light is flashing away.
I have also replaced the ecu ignition barrel and keyless entry and relevant key for the ecu but still no joy, iam lost now god knows what the problem is relays and fuses look to be ok.
any help would be great
Do you have two keys?
Take it to Mazda for a code check.
If the keys match the keyless unit & the transponder ring on the ignition barrel then it should be able to be coded to the ECU &/or Instrument cluster.
You may need a new key by Mazda or another provider. I think you will need to proof ownership of the vehicle so Mazda can get you a new set of keys for a not so small fee.
I would call a Mazda dealer for information. Then I would cross check online to look for alternatives.
Maybe you can hack and fix the antenna (isn't that an aerial?) of your existing key.
thaiball
11-18-2010 03:34 PM
