Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Protege
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 02-21-2009, 07:01 PM
Default windshild whiper fluid doesn't spray but wipers work fine
Hi, so the other day I was driving fine using my wipers and the fluid good there was no problems or nothing so I parked my car. 3 hours later when I came back out and started my car everything was fine after when I tried to spray my fluid onto my windshield to clean it nothing came out the wipers would work fine but no fluid came out. I tough it might be that I was empty so I went and bought more windshield fluid and wen I tried to use it same problems. Any Idea's of what could of happen everything was fine and 3 hours later it doesn't work anymore?
Register today for free or log-in if already registered to remove this ad!
Old 02-22-2009, 12:02 AM
wsoape281's Avatar
there is a little pump on either the top or bottom of the bottle that you could check on. i have never personally serviced it, so that is all of the advice that i can give you.
__________________
My name is Wes, and i am a boostaholic
Old 02-22-2009, 01:44 AM
I'll do you one better. Mine started doing the same thing about 2 months ago. Except, some times it'll go a few days where it won't spray, then for a couple days it will spray. I knew the wipers had an intermittent option but I didn't think the sprayer did as well???
Old 02-22-2009, 12:42 PM
is there any ice/snow covering the nozzles?
__________________
-- Willem
2001 Mazda Protege ES
Old 02-22-2009, 01:42 PM
I looked and I couldn't find the pump on top of the bottle. No there's no ice or snow covering the nozzle they look perfect. would you know how to fix that intermittent option or do did u wait it out?
Old 03-06-2009, 05:03 PM
how cold is it ? what temp is washer fluid rated ? does the washer fluid work after engine warms the engine compartment? this can be a reason for intermittant washer spray
Old 03-17-2009, 01:00 AM
Trace the washer plumbing backwards to as close to the reservoir bottle as you can. Disconnect the tubing there and try the squirt with wipers running. If it "pees" fluid, the problem is obstructed nozzles or plumbing, possibly due to freeze up. If it doesn't "pee", its electrical, i.e. pump, wiring, fuse, or stalk switch related.
With the engine stopped, turn the key to pre-start, i.e. all the instrument panel warning lights on. Operate the spray and the wipers should run for several wipes, and you should be able to hear the washer pump motor running. If the squirt works on some of the wiper switch settings but not on others, the problem is with the stalk switch.
Old 03-24-2009, 08:21 PM
NightSwimmer's Avatar
oldeng's advice is good. If you have fluid spray with the tube disconnected from the spray nozzles, then your pump and electrics are okay. I had this problem once and it was caused by debris in the spray nozzles. I used a sewing needle to clear the obstruction. My nozzles were like little ball sockets inside a mounting bracket and I had to re-aim them by sticking the needle back into the nozzle and moving them around after I cleared the obstruction. On the first try, they sprayed up over the top of my windshield.
Tags
disconnect, fluid, locate, mazda, motor, nozzle, spray, sprayer, squirt, tribute, waser, washer, windshield, wiper, wipers, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
