2000 Protege heater works but no defrost
Old 02-25-2013, 02:57 PM
2000-mazda-protege's Avatar
Default 2000 Protege heater works but no defrost
Need help with my daughter's 2000 Protege.
The heater works great and blows out the front and bottom but it won't blow out the top (defrost).
Old 02-25-2013, 07:16 PM
tanprotege's Avatar
The climate control looks like this:
I think I can tell the selector is electrical. On the receiving end of the harness should be an actuator that operates a door inside the air box. This door is either jammed or the actuator is broken or the circuit is interrupted. That interruption could be caused by a bad switch, a short to ground, a short between wires etc.
A thourough inspection should let you find the culprit.
If it happens to be cable operated it is purely mechanical and you may find a broken plastic piece or detached cable.
Good luck.
Old 02-26-2013, 06:20 AM
Thanks for your help!!
onig6725
04-01-2011 06:30 AM
Mazda_Protege_2000
01-30-2011 05:37 PM
Spilk
10-12-2007 05:51 PM
mazda_roller
02-22-2007 06:38 PM
tmyers
02-19-2007 02:35 PM
Quick Reply: 2000 Protege heater works but no defrost
