transmission mounts - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 11-24-2005, 04:34 AM
Default transmission mounts
What might I expect to pay to have a transmission mount replaced on my '99 Mazda Protege (part/labor)?
I understand it is not as tough as replacing a motor mount, but how long should it take my shop to replace?
Thanks!
Old 11-27-2005, 01:20 AM
Default RE: transmission mounts
Which mount are you looking at having replaced? Is it the one on left side under air cleaner housing? Up front by the radiator, or rear back by the firewall? What engine size as well? Auto or manual trans? Can get you price and part number with above info as well as estimate for time.
Old 11-28-2005, 03:39 PM
The transmission mount is rear back by the firewall.
Mazda Protege ES, 1.8-liter 4-cylinder, manual 5-speed.
Thanks!
Old 11-28-2005, 07:33 PM
Take a look at your vehicle build date located on the drivers b-pillar. Should be on a sticker just below your door striker. There are two different mounts depending on when was built. If built between 12/01/1998 and 04/15/1999 then you need a Mazda part #B25D-39-040C that retails for $83.05. Available from onlinemazdaparts for $66.44. If built after 04/15/1999 then will need Mazda part #BJ0N-39-040C that retails for $49.80. $42.33 from online.
Labor listed in Mitchell is 1.1 hrs for trans mount. Dollar amount will depend on labor rate that your shop charges.
Old 11-28-2005, 10:11 PM
Thank you! I appreciate the info very much!
Thread Thread Starter Forum Replies Last Post
1998 Protege ES Motor Mounts liz4jim Mazda Protege 0 08-05-2011 02:04 PM
Mazda 3 engine mounts - oil filled? jswilson64 Mazda3 6 03-04-2008 04:46 PM
Are Mz3 engine mounts fluid filled? germanshepherd Mazda3 1 07-26-2007 11:14 PM
new motor mounts wsoape281 Mazda Protege 1 03-03-2007 05:30 PM
Engine Mounts vs. Auto Trans - ECU wkhoury Mazda6 0 04-13-2006 03:53 PM
Tags
1999, 2005, 98, forum, long, mazda, mitchell, motor, mount, mounts, protege, replace, replacing, time, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
