Tail lights not working
Old 09-22-2006, 12:59 AM
Kailem's Avatar
Default Tail lights not working
My tail running lights are not working and neither is my dash back light, both seem to have gone off at the same time as near as I can tell. My brake lights, blinkers, headlights, high beams, and other dash lights (high beam indicator, blinker indicators) all work. I checked the fuse for the tail lights, replaced it though it was fine. Checked the fuse box for power and it had it. Replaced all the tail lights. Why won't my tail lights work? I've looked through my Hayes manual and can't find anything remotly helpful.
Thanks in advance.
Old 09-22-2006, 07:59 PM
bkey71's Avatar
Default RE: Tail lights not working
What are you working on?
Old 09-10-2007, 02:39 PM
Hi..I have the same prob on my '94 626..the problem isin the turn signal switch..not making a ground somewhere..sprayed the hell out of it with contact cleaner but no luck..Let me know if you find out how to remove the switch cover at the end of the shaft..Thanks and GL on it..Medge
Old 09-10-2007, 05:10 PM
hixx's Avatar
The headlight switch can be removed/disasembled and cleaned pretty easily. Just clean the contacts with sandpaper then contact cleaner. It is best to disasemble it on a piece of cloth as there are small springs that can be lost.
CanAva
06-09-2019 07:35 AM
Auburngal
01-17-2012 08:52 AM
SanCarlos_Tribute
02-28-2011 08:19 PM
jpaschal21
06-17-2009 06:56 PM
Quick Reply: Tail lights not working
