Rear Brakes - 2002 Protege 5
Old 07-01-2007, 01:38 PM
kam's Avatar
kam
kam is offline
Default Rear Brakes - 2002 Protege 5
Need todo rear brakeson 2002 Protege 5, but can't find manual. Does Hanyes have one for this year? Having dificulties with Caliper. Any suggestions?
Thanks!
Old 07-01-2007, 02:26 PM
wsoape281's Avatar
Default RE: Rear Brakes - 2002 Protege 5
on the back side of the caliper, there is a 14mm bolt that you need to pull. under that bolt there is an allen head screw that you will back outand the caliper will open. if you need a picture, i think i have one.
Old 07-01-2007, 05:54 PM
kam's Avatar
kam
kam is offline
Does just the one bolt come off? A picture would be great. Thanks!!!
Old 07-01-2007, 07:37 PM
wsoape281's Avatar
look at the big red circle. that is the bolt that you will have to remove. it is on the back of the caliper (on the inside of the wheel well) when the caliper is mounted. you will pull that, then back out the allen bolt that is inside of there. i had the same problem with my pro 5 and i had to go to my dad for help (so degrading, considering our relationship) and we figured it out.
Old 07-03-2007, 06:06 AM
i dont think Haynes made manual for PR5..
thanks for the info wsoape281
Old 07-03-2007, 05:20 PM
babyhuey's Avatar
Just a note to add to wsoape281's post.
Rotate the allen screw counterclockwise to draw thepiston back into the caliper. Once you feel a increase in resistance then stop or the screw splines can be easily stripped out. Once the pads are installed and caliper reassembled then rotate the allen screw clockwise while turning the rotor. When the caliper just locks up the rotor rotation then stop and turn the screw back counterclockwise 1/2 of a turn to set the intial adjustment. No adjustment should be needed after that. Hook up the parking brake cable after adjustment has been made.
Old 09-03-2007, 10:15 AM
hey kam, look for the brakes section on this shop manual...
http://protege5.ugly.net/#ac
you shold be able to find anything related to your 2002 protege 5.....
Old 09-14-2011, 10:09 AM
trophy winner's Avatar
just did mine same make and model.opposite of the hydrolic arm is a nut with a hex adjuster inside of it.if you unscrew the hex adjuster the arm releases out of way.then just slip in pads and put it all together
mertl
06-15-2010 07:47 PM
Hidayaco2
03-13-2010 03:35 PM
absolutjk
01-10-2009 01:32 PM
AutoFTW
08-03-2008 06:53 PM
bkeogan
04-23-2004 11:17 PM
Quick Reply: Rear Brakes - 2002 Protege 5
