Radiator Overheating/Cooling Problem
Old 08-11-2016, 08:42 AM
juice714's Avatar
Default Radiator Overheating/Cooling Problem
Hi, first of all I'm a chic, which is not to say all chic's don't have a clue as to the mechanics of a car, but this chic is limited. So here's my problem. My 2000 Mazda Protege (1.6 4L) was overheating. The radiator was leaking badly. So, I replaced the radiator. Still overheating. So I then noticed the cooling fan (the one on the drivers side) was not coming on so I replaced that also. And yes, it does come on. I checked it by turning on the a/c and both fans now spin. I took the car for a test drive and the damn thing overheated AGAIN. Now I noticed that the fan not only comes on but it STAYS on. Should it not cycle on and off? I drove for a good while and the temp gauge stayed in the optimum range for quite some time before it started creeping up into the red zone. Also, it seemed that it would start to creep up while at a stop and then drop a bit when I accelerated before deciding no, it did indeed want to overheat. AGAIN. What to look for now? Relay switch? Something not connected correctly? What? Please help!! I'm not scared to get under the hood and give it a try if I'm not removing too many parts, lol.
Old 08-12-2016, 04:31 AM
Carry out a TK test ( combustion gases in coolant) if that passes then,
Remove your thermostat, flush the entire cooling system, fit a new thermostat, fill the cooling system with the correct type & concentration of coolant, bleed the system then fit a brand new radiator cap.
Road test & report back.
alpajack
06-18-2013 01:44 PM
dlsummers1216
10-15-2010 11:45 PM
bustedmycar
09-22-2009 07:48 AM
jhasdmcier
07-20-2007 09:26 AM
Quick Reply: Radiator Overheating/Cooling Problem
