Protege5 Sputtering sound, may not be misfiring
Old 06-27-2014, 04:00 PM
oglesbymt's Avatar
Cool Protege5 Sputtering sound, may not be misfiring
I have a 2002 Protege5, and it has had a faint sputtering sound for about 8 months. I haven't felt it misfire until last week. I replaced the spark plugs and coils, as well as cleaned out the mass air flow. It does not idle rough, but I can still hear a sputtering sound when I accelerate.
My question: The exhaust already has a sputtering sound when idled, so could it just be my exhaust I'm hearing?
Thank you!
Old 06-28-2014, 08:43 PM
Juanky's Avatar
do you have any trouble codes?
Old 06-28-2014, 09:45 PM
have you had the car since new?
Did someone fart around with any catalytic converters?
Mileage?
Old 06-29-2014, 07:15 AM
oglesbymt's Avatar
It's giving me the O2 sensor code, I bought it used at 118,000 miles, and it currently sits at around 128,000 thousand miles.
Old 06-29-2014, 07:17 AM
oglesbymt's Avatar
That's a great point about the previous owner. I'll check my car for alterations.
Old 06-29-2014, 07:59 AM
READ: https://www.mazdaforum.com/forum/gen...effects-30404/
Gutting cats, although illegal, are not bad for engine. Nothing really much too worry about mechanically speaking unless you get a cel code then when you get another issue, you will never know as cel code always present.
Old 06-29-2014, 09:41 AM
Juanky's Avatar
the upstream o2 sensor is used to adjust the fuel trims. if the heater is bad, then it might work ok after the engine heats up. if the sensor is bad, then your fuel trims will be affected and you might get random misfires(another code). the downstream sensor just tells is the cat converter is working and has no effect on the engine. can you give us the code?
Old 06-30-2014, 11:52 AM
oglesbymt's Avatar
I'll swing it by the store today and get the code.
Cramm557
12-01-2010 03:44 PM
virgin1
11-12-2010 05:47 PM
introuble
01-25-2010 08:24 AM
BettermanNZ
08-14-2007 07:59 PM
maxvtec7500
10-29-2006 11:05 PM
Quick Reply: Protege5 Sputtering sound, may not be misfiring
