More p0300 protege
Old 11-23-2011, 10:49 AM
mazda burner's Avatar
Default More p0300 protege
My 2003 Protege LX 5speed 105k km is getting engine code p0300 random misfire. If I run the car from cold, get into 5th gear and drive steady 3000 rpm for 15km it stalls like someone pulled a plug wire for 5 seconds, engine light comes on then car is ok. It is the only time it will do it. If I go up and down through the gears or let it warm up completely before driving, it is fine no P0300. I have read quite a lot of threads here and elsewhere regarding code P0300. I have replaced EVERYTHING. Coils, plugs, wires, EGR, front and back CAT sensors, rear CAT. run premium fuel. To no avail. This car is about to star in a youtube pyro video. HELP.
Old 11-26-2011, 05:37 PM
tanprotege's Avatar
I kind of think that it is electrical. I would wiggle check all wire harnesses I can get to while idling. If you can produce the miss that way you have a suspect.
Disconnect, inspect, clean and reconnect anything. Don't forget the ground connections.
Good luck to you. I know it is frustrating.
modpup
11-28-2017 08:43 PM
mizaro
10-04-2015 08:27 AM
TristanP
01-12-2012 06:32 PM
Swoop
08-22-2009 01:06 AM
buldozr
01-18-2007 11:21 PM
Quick Reply: More p0300 protege
