Mazda 323 1.5 1998 BJ Problems acceleration
Old 11-01-2015, 01:28 AM
UlrikOlsen's Avatar
Default Mazda 323 1.5 1998 BJ Problems acceleration
Hello Forum
I just bought this car, and seller told me there was some minor problems with engine stalling under acceleration.
The car don't have OBD, but only diagnostics in the engine bay. (can someone help me with the correct diagram, on how to read out fault codes?). I found some diagrams on google, but when i try to connect it as shown... My Engine fan starts up? And no codes are shown.
Also i've checked for vacum leaks, cleaned MAF, changed Plugs and Coils.... Nothing helped...
Does anyone have an idea?
Old 11-04-2015, 04:43 PM
tanprotege's Avatar
Old 11-04-2015, 10:46 PM
UlrikOlsen's Avatar
Yes I've read it, and checked as much as I can.
I haven't checked my catalytic converter, because I'm not sure how to check if it is ok?
Also I'm not sure if my car have EGR... But I don't think so since there is a plate mounted on the inlet manifold, and also the pipe from exhaust is blinded/blocked.
Can anyone help me how to read out any fault codes, from the diagnostics in the engine bay ?
Sorry for my bad english, but I'm from Denmark :-)
Old 11-04-2015, 11:36 PM
tanprotege's Avatar
You don't have an EGR system. That's good!
Are you sure there is no OBDII connector under the dash? If not there should be a connector in the engine bay near the fuse box.
Old 11-05-2015, 12:40 PM
UlrikOlsen's Avatar
I'm pretty sure the car only have Diagnostics in the Engine bay, and no ODB 2 like newer cars... I got a diagram for Mazda 323 BJ 1.6, and when i connect like it says, my engine fan starts blowing, and no codes are shown ???
Please help
Old 11-05-2015, 07:23 PM
tanprotege's Avatar
I don't know how I can help. Here all '95 and later protege have OBDII under the dash.
Old 11-05-2015, 11:03 PM
UlrikOlsen's Avatar
My car is build in Japan, if that makes any difference?
I will check under the dash, to make sure one more time...
Old 11-06-2015, 10:35 PM
tanprotege's Avatar
It does not matter so much where the car was built. It matters more for which market the car was built. That is the reason why you don't have an EGR system. I don't know what else is different from the US models.
You may have to look for help locally.
All the best!
Tan
JCWILBU
10-23-2023 09:56 PM
Bfunk
06-13-2011 02:41 PM
emily6371
08-20-2009 01:26 AM
nmcdaniel24
11-29-2006 10:54 PM
txaggie
04-18-2006 01:04 AM
Quick Reply: Mazda 323 1.5 1998 BJ Problems acceleration
