Driver side front issue
Old 11-03-2017, 10:20 PM
Sean Tucker's Avatar
Default Driver side front issue
so last weekend I changed the drivers side front bearing, lower control arm and putter tie rod. At first I didn’t notice anything wrong but on my 45 min drive home at speeds much higher then city (50km) there was a wobble and when I used the breaks they pulsed on that side. Could the bearing have not ceated properly or could the rotor be shot? Before doing the bearing there was no wobble and no pulsing.
To to clarify I changed the same parts on the passenger side the weekend before and rode great.
Old 11-04-2017, 03:18 AM
Go back & re-check everything you've done.
Old 11-04-2017, 01:14 PM
I have done that a few times now. I just checked it and when I loosened off that 1 inch 1/4 centre nut there was quit a bit of play between the main hub and the other side of it. (I’m no mechanic so using lamens terms cause that’s all I know)
punkascii
08-10-2009 05:34 PM
suyeda16
05-12-2008 12:21 PM
toloquta
12-21-2007 04:33 PM
sstockton
08-15-2007 05:51 PM
Quick Reply: Driver side front issue
